Mini-Mendel/Spacexula Documented Build
Revision as of 04:23, 26 November 2011 by Glenn (talk | contribs) (+ Category:Mini-Mendel Variation)
Mini-Mendel Documentation
There are six stages to making RepRap Beta "Mini Mendel". They are:
  1. Downloading and Installing RepRap on your computer
  2. Circuit board construction
  3. Microcontroller firmware installation
  4. Mini Mendel Mechanical construction
  5. Mini Mendel Electronic wiring
  6. Mini Mendel Commissioning
If you do each in the order above, you will be able to use what you have done so far to test each new stage. Follow those links to find out how to do each.
