Lalita
Lalita
Release status: Working
Description | a foldable RepRap 3D printer.
License | GPL
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Advertisement
This is the first time this design is being published. PLEASE WAIT and give me time to publish all the information, please don't start to buy or build this design. I'm working on this page.
Introduction
Non printed parts
MAKERBEAM :
10mm x 10mm profile | Quantity |
300mm long | 4 pcs |
200mm long | 6 pcs |
150mm long | 4 pcs |
60mm long | 6 pcs |
Others from makerbeam | Quantity |
Square headed bolts 6mm | 42 pcs |
Regular nuts m3 | 58 pcs |
Countersunk bolts m3 10mm | 36 pcs |
Cap head allen bolts m3 10mm | 20 pcs |
threaded rod m4 200mm | 2 pcs |
MECHANICS:
Description | Quantity |
stepper NEMA14 | 5 pcs |
linear bearing lm6uu | 10 pcs |
bearing 623 | 4 pcs |
Screw M5 x 40mm | 4 pcs |
Regular nuts M5 | 6 pcs |
This is not a complete list of all the parts and materials yet... i'm sorry, working on it!!
Printed Parts
Piece | Quantity | Description | link |
12 pcs | print this w/o support material | File:Lalita corner.stl | |
4 pcs | File:SoporteBarra.stl | ||
1 pc | Don't need support | File:MotorY.stl | |
1 pc | File:RodamientoY.stl | ||
1 pcs | Y belt holder for gt2 | File:Correa.stl | |
3 pcs | File:Linear bearing.stl | ||
1 pcs + 1pcs mirroed | Print one normal and one mirroed | File:Basegiro.stl | |
1 pcs + 1pcs mirroed | Print one normal and one mirroed | File:Giro.stl | |
1 pcs + 1pcs mirroed | Print one normal and one mirroed | File:Barra sup.stl | |
1 pcs + 1pcs mirroed | Print one normal and one mirroed | File:Z motor.stl | |
1 pcs | Remove the support material after print | File:IddlerX motor.stl | |
1 pcs | File:IddlerX i.stl | ||
1 pcs | File:CarroX v2.stl | ||
1 pcs | File:Alu hot end.stl | ||
1 pcs | File:E3d part A.stl | ||
1 pcs | File:E3d part B.stl | ||
6 pcs | File:Correa623.stl | ||
2 pcs | File:Y lock1.stl | ||
2 pcs | File:Lalita Palometa.stl | ||
2 pcs | File:Cono palomenta.stl |
Extruder
This extruder works with a mk8 1.75 drive gear and a 1/8" Male Thread Quick Connect
PRINTED PARTS
1 | File:Bisagra.stl | ||
1 | File:Soporte.stl | ||
1 | You have to end drills with a 3mm drill | File:Cuerpo.stl | |
1 | You have to end drills with a 3mm drill | File:Palanca.stl |
This is not a complete list of all the printed parts... i'm sorry, working on it!!
External links
[1]link to spanish reprap comunity. Topic of lalita.
