2xz+
Revision as of 16:21, 17 April 2016 by Iran (talk | contribs)
i3 2Xz+
The i3 2Xz+ is an
improved and enlarged Prusa i3.
GPLv2
The i3 2Xz+ is an improved and enlarged tested successor of the original Prusa Mendel i3.
Either you want to create a huge 40x20x30 machine from scratch or you want to upgrade your existing Prusa i3 (or its derivatives) to a machine with dual heated beds and more than doubled printing space, i3 2Xz+ is a well documented and tested machine suitable for you.
Improvements
All improvements where done after identifying problems of various prusa i3 based machines during 2 years of creating and selling reprap 3d printers. Many Open Hardware projects were used in this version, Which are carefully selected among a huge number of tested open source 3d printer parts and upgrades available online.
  • An enlarged rigid 10mm acrylic frame (any other suitable material can be used).
  • All electronics are supported, preferably 12v 30A power supply, Ramps 1.4, and the full graphic smart controller LCD display.
  • Wiring is managed perfectly, all the paths and routes are reconsidered, you won't need to invent any solution for managing wires.
  • Uses two separate [standard PCB mk2 heatedbeds] .
  • Dual Geared bowden extruder using MK7 extruder gears, Provide precision and power at the same time.
  • PSU switching is completely shielded and secured, There is a PC style On/off switch and power inlet added.
  • There are two well mounted ON/OFF Switches, one for the LED lights under the extruder heads, and the other one for manually enabling the second heated bed, in order to save energy on smaller prints.
  • Sufficient cooling system on ramps 1.4 board including two dedicated cooling fans one for regulators and one for stepper drivers.
How to get it?
Some Videos of i3 2Xz+ working:
visit i32Xz+ youtube chanel <videoflash type="youtube">kB88AeT0NjE</videoflash>] <videoflash type="youtube">6XHytc8BfAc</videoflash>]
Get in contact with us!
Please contact us through our website trough the contact form.
