Skip to topic | Skip to bottom
Home"Wealth without money..."
Main.PonokoRepRapXMotorAssemblyr1.13 - 02 Jan 2009 - 23:55 - VikOllivertopic end
Start of topic | Skip to actions
Ponoko RepRap X Motor Assembly
Main Ponoko Page
Prev StepNext Step
BOM for this page
The X Motor assembly can be fitted with either a NEMA17 or NEMA23 stepper motor. With the larger NEMA23 design, the motor body itself is used to trap the X Carriage guide rails to the X Motor Bracket. With the NEMA17, the motor is screwed directly to its bracket and acrylic clamps are used to hold the guide rails in place.
Ponoko RepRap X Axis gear components First, locate the size of rims and gear that (a) fits the shaft on your stepper motor, and (b) fits the type of ball chain that you have purchased. The rims and gear are cut for a 4mm and 6mm shaft. If you have a 5mm shaft, look for the larger ball chain gear. In its hole you will find a 5mm collet. Carefully separate the collet from the gear and use it to adapt your 5mm shaft into a 6mm shaft. If the gear or rim does not quite fit the spindle of the motor, file away on the interior flat surface of the gear or rim with a small flat file until it just fits. If you have no flat on your stepper motor, clamp it in the jaws of a vice and put one there with a 2nd cut file.
Once you have something that fits on, scrape the motor shaft with the file a bit to give it some edges to catch the epoxy, and epoxy the rim/gear/rim sandwich into place right at the end of the shaft. Make sure all is square before the epoxy sets.
Try not to fill the teeth of the gear with epoxy. If you do, try not to wipe it out with a solvent-soaked rag that dissolves the acrylic...
Some form of test on some scrap is in order.
Completed X axis assembly Here is a complete set of parts for the X Motor Assembly, using a NEMA 17 stepper motor. For a NEMA 23 motor, two of the Rail Clamps and their fastenings will not be needed, but 4 M5 25mm screws with 8 M5 washers and 4 M5 nuts not shown here will be:
End Spacer with 4 bolts Put washers on four M3 16mm screws, and insert them into the X End Spacer as shown. Only use nuts, not washers on the other side as these nuts will become captive later.
X Motor Bracket with Rail Clamps. NEMA 17 only. Locate these parts for assembling the X Motor Bracket from the 5mm acrylic sheet:
Putting clamps on X Motor Bracket. NEMA 17 only. (NEMA17 Only) Put washers on four M3 25mm screws and put them through a rectangular Rail Clamp. Insert this into the matching four holes in the large X Motor Bracket and secure with washers and nuts. Repeat for the matching Rail Clamp on the X Motor Bracket.
X Motor Lower Bracket Locate the parts for the X Motor Lower Bracket as shown here:
X Motor Lower Bracket assembly. Take the X Motor Lower Bracket and attach the two Rail Clamps as per the X Motor Bracket, but insert the four M3 25mm screws into the Bracket first, not the Clamp. Put washers on four M3 25mm screws and put them through the Bracket first (not the Rail Clamp as you might have done for the X Motor Bracket). Insert this into the matching four holes in the Rail Clamp and secure with washers and nuts. Repeat for the matching Rail Clamp on the other end of the X Motor Lower Bracket.
X Motor Lower Bracket complete. The completed X Motor Lower Bracket Assembly.
X Motor Y Saddles. As per X Idler. Assembling the Y Saddles is exactly the same as building the ones for the X Idler Assembly. Recapping: Assemble one Y Saddle with the 5mm chain clamp against one side, and a second with it on the other. The two clamps should be mirror images of each other. Use 4 M3 20mm screws, a pair of washers each, and nuts.
Y Saddle Assembly component order Just to remind you, this is the order in which the Y Saddles are braced together. Put washers on two M3 40mm screws and slide them into the clamp side of one of the Y saddles. Slide on one or two washers - the exact number depends on the thickness of your "8mm" and "5mm" acrylic. You might not need any.
End Spacer with Y Saddles attached. Attach the Y Saddle Assembly to the End Spacer using four M3 12mm screws with washers, and captive nuts as with the X Idler Assembly. Do not tighten fully. Wait until the X Axis Assembly is mated with the Y Axis for that.
X Motor Bracket Assembly awaiting actual motor If you're using a NEMA 17 motor, fit it now. Don't know what kind you're using? NEMA 17 only fits the small set of 4 slotted holes, NEMA 23 only fits the larger set that extend into the little triangular "wings" on the X Motor Bracket.
Method of trapping guide rails against NEMA23 motors (NEMA23 Only)If you're using a NEMA 23 motor, you will fit it later, using it to trap the Guide Rails against the X Motor Bracket as shown here:
If the NEMA23 motor appears unstable due to short rails or a strangely-shaped front on the motor, chock up the far corner with a piece of scrap 8mm acrylic.
Completed Ponoko X Motor Assembly When it's all put together properly, the X Motor Assembly (this one fitted with a NEMA 17 motor) looks like this:
Now put all the X Axis parts away safely and we'll move on to the Corner Assemblies.
Main Ponoko Page
Prev StepNext Step
-- VikOlliver - 07 Nov 2008
to top
I Attachment sort Action Size Date Who Comment
dsc04252.jpg manage 60.3 K 21 Oct 2008 - 08:57 VikOlliver Set of parts for Ponoko RepRap X Motor Assembly
dsc04235.jpg manage 65.5 K 21 Oct 2008 - 08:58 VikOlliver Completed Ponoko RepRap X Motor Assembly
dsc04236.jpg manage 69.5 K 21 Oct 2008 - 09:10 VikOlliver Ponoko RepRap X Axis gear components
dsc04300.jpg manage 71.2 K 21 Oct 2008 - 09:35 VikOlliver Method of trapping guide rails against NEMA23 motors
dsc04251.jpg manage 61.7 K 25 Oct 2008 - 03:54 VikOlliver End Spacer with 4 bolts
dsc04250.jpg manage 66.3 K 25 Oct 2008 - 03:55 VikOlliver X Motor Bracket with Rail Clamps. NEMA 17 only.
dsc04249.jpg manage 65.1 K 25 Oct 2008 - 04:00 VikOlliver Putting clamps on X Motor Bracket. NEMA 17 only.
dsc04248.jpg manage 68.6 K 25 Oct 2008 - 04:01 VikOlliver Assembled X Motor Bracket Rail Clamps. NEMA 17 only.
dsc04247.jpg manage 63.5 K 25 Oct 2008 - 04:02 VikOlliver X Motor Lower Bracket parts
dsc04246.jpg manage 72.6 K 25 Oct 2008 - 04:03 VikOlliver X Motor Lower Bracket assembly.
dsc04245.jpg manage 68.0 K 25 Oct 2008 - 04:04 VikOlliver X Motor Lower Bracket complete.
dsc04243.jpg manage 74.9 K 25 Oct 2008 - 04:05 VikOlliver X Motor Y Saddles. As per X Idler.
dsc04241.jpg manage 67.4 K 25 Oct 2008 - 04:06 VikOlliver Y Saddle Assembly component order
dsc04239.jpg manage 62.8 K 25 Oct 2008 - 04:07 VikOlliver End Spacer with Y Saddles attached.
dsc04238.jpg manage 58.4 K 25 Oct 2008 - 04:08 VikOlliver X Motor Bracket Assembly awaiting actual motor
You are here: Main > PonokoRepRap > PonokoXAxisAssembly > PonokoXIdlerAssembly > PonokoRepRapXMotorAssembly
to top
Copyright © 1999-2009 by the contributing authors. All material on this collaboration platform is the property of the contributing authors.
Ideas, requests, problems regarding RepRap? Send feedback
