Skip to topic | Skip to bottom
Home"Wealth without money..."
Main.PonokoRepRapXAxisAssemblyr1.21 - 07 Mar 2009 - 01:33 - VikOllivertopic end
Start of topic | Skip to actions
Ponoko RepRap X Axis Assembly And Installation
UNDER CONSTRUCTION
Main Ponoko Page
Prev StepNext Step
BOM for this page
Assembling the Ponoko X axis vertically. When you're building the X Axis Assembly, assemble the pieces vertically as shown. This makes it easier to keep bits that should stay out of the way out of the way, particularly when fitting the 8mm rods:
You will need the X Motor Assembly, X Idler Bracket Assembly and X Carriage assembly. If using a NEMA17 motor to drive the X Axis, you will need four 8mm diameter 500mm long bright steel rods. If using the larger NEMA23 motor, you will need two 8mm diameter 500mm long bright steel rods for the lower pair and two 520mm bright steel rods for the top pair to give better stability. There is also an X Opto Bracket to be fitted (it's the one marked "X"...), with an attendant M5 nut and M5 8mm grub screw.
Complete & fitted X Axis Assembly Slide the 500mm rods through the carriage first, as it holds them in roughly the right spacing.
Fit the Opto Bracket before you forget.
Slide the two end assemblies on, wriggling the rods into the holes in the End Spacers, then adjusting the screws on the Rail Clamps. At some point, standing it on its end as shown above becomes the easier option.
This is what it looks like after it's been fitted to the Y Guide Rails:
X Carriage mounted with chain fitted. The X stage needs 1200mm of 3.5mm ball chain. This shows how the ball-chain is fastened to the X Carriage. Run it around the X Motor Gear, through the slots in the Carriage and End Spacers, around the Idler and fasten using the Carriage clamps.
Use the fixed Clamp to anchor the chain initially, then use the sliding Clamp to apply the final tension and fasten the chain off. Make it sufficiently tight to prevent the chain falling off the Motor gear, but not excessively tight as this makes the Carriage harder to move and increases wear.
X Motor Assembly with Y Saddles gripping Y axis. This shows how to fit the Y Saddles onto the Y axis. Make sure both sets of Y saddles are square before you do up the nuts connecting them to the End Spacers. The Y Saddles pull the X Axis Assembly down onto the Y Guide Rails, preventing it from rocking as the Carriage or Y Axis moves.
The green stuff in the left of the photo is a reflection from a Darwin Paste Extruder fitted into the Extruder Socket.
You remembered to fit the X Opto Bracket, right?
Ball-chain and useful tools The Y stage needs two lengths of 1200mm 3.5mm (#6) ball chain, one for each side. You may need a third or fourth hand to get and keep them in place while you adjust them. Locking forceps and bulldog clips come in handy too.
Measuring Y Axis chain You should have this much chain plus enough to run through the chain clamps. Note that this is NOT the routing of the chain. It goes in-between the X axis rods, with the ends on the bottom side.
Y Chain fitted loosely One end of the Y Chain fitted loosely into the Y Saddle Chain Clamp.
Machined bolt heads You may need to file down the diameter of the M5 bolt heads to get them to fit snugly into the NEMA 23 motor mounts. The instructions for using NEMA 17 motors haven't been written yet. You're on your own.
14mm thread overhang on Y Drive Rod Leave 14 mm of Y Drive Rod extending beyond the motor mount bracket. This will give you sufficient room to attach the Y Motor Coupling.
Parts for Y Motor mounting You'll need these parts for the Y Motor Mount.
Fitting spacers to Y Motor Insert four M5 50mm screws into the NEMA 23 flanges, and tighten nuts on them. The Y motor needs to be mounted some distance away from the Y Drive Rod to leave room for the Y Motor Coupling. Use six M5 spacers cut from 5mm acrylic plus one M5 spacer cut from 3mm acrylic, plus a washer.
Fitting Y Motor Coupling to Y Drive Rod Put a washer on a 3 M3 25mm screws, and insert them into a 3mm Motor Coupling disc. Using a M8 nut, washer, and half-nut, attach the Motor Coupling disc to the Y Drive Rod (remember, you left 14mm of it sticking out).
Y Motor plate on Coupling Put three M3 spacers cut from 8mm acrylic on the screws, the pictured 5mm acrylic ball chain gear with grub slot (or the custom 8mm acrylic equivalent for later kits), washers, and nuts.
Y Motor plate with nut and grub Insert a M5 nut and M5 8mm grub screw into the slot.
Shuffling nuts on Y Motor mounting using thumb Using a washer and nut on the four 50mm screws, attach the Y Motor to the Y Motor Mounting Plate. Rotate the ball chain gear until you find the flat on the motor shaft, and tighten down the grub screw.
Finished Y Motor mounting. Now secure Y Drive Chain Fasten the Y Drive Chain on both sides.
Tension Y Chains Tighten the Y Saddle Chain Clamps so the X Axis Assembly is square.
Main Ponoko Page
Prev StepNext Step
-- VikOlliver - 07 Nov 2008
to top
I Attachment sort Action Size Date Who Comment
dsc04288.jpg manage 77.2 K 22 Oct 2008 - 09:35 VikOlliver Assembling the Ponoko X axis vertically.
dsc04290.jpg manage 77.3 K 25 Oct 2008 - 04:23 VikOlliver Complete & fitted X Axis Assembly
dsc04254.jpg manage 67.2 K 25 Oct 2008 - 04:24 VikOlliver X Motor Assembly with Y Saddles gripping Y axis.
dsc04398.jpg manage 68.4 K 07 Nov 2008 - 05:32 VikOlliver X Carriage mounted with chain fitted.
dsc04565.jpg manage 65.4 K 07 Dec 2008 - 05:10 VikOlliver Ball-chain and useful tools
dsc04570.jpg manage 74.5 K 07 Dec 2008 - 05:11 VikOlliver Measuring Y Axis chain
dsc04572.jpg manage 57.7 K 07 Dec 2008 - 05:11 VikOlliver Y Chain fitted losely
dsc04580.jpg manage 66.1 K 07 Dec 2008 - 05:12 VikOlliver Machined bolt heads
dsc04582.jpg manage 63.1 K 07 Dec 2008 - 05:12 VikOlliver 14mm thread overhang on Y Drive Rod
dsc04584.jpg manage 57.6 K 07 Dec 2008 - 05:13 VikOlliver Parts for Y Motor mounting
dsc04585.jpg manage 57.4 K 07 Dec 2008 - 05:13 VikOlliver Fitting spacers to Y Motor
dsc04588.jpg manage 74.8 K 07 Dec 2008 - 05:14 VikOlliver Fitting Y Motor Coupling to Y Drive Rod
dsc04589.jpg manage 72.1 K 07 Dec 2008 - 05:14 VikOlliver Y Motor plate on Coupling
dsc04590.jpg manage 74.4 K 07 Dec 2008 - 05:15 VikOlliver Y Motor plate with nut and grub
dsc04591.jpg manage 68.4 K 07 Dec 2008 - 05:15 VikOlliver Shuffling nuts on Y Motor mounting using thumb
dsc04592.jpg manage 66.8 K 07 Dec 2008 - 05:16 VikOlliver Finished Y Motor mounting. Now secure Y Drive Chain
dsc04575.jpg manage 69.8 K 07 Dec 2008 - 05:19 VikOlliver Tension Y Chains
Copyright © 1999-2009 by the contributing authors. All material on this collaboration platform is the property of the contributing authors.
Ideas, requests, problems regarding RepRap? Send feedback
