Skip to topic | Skip to bottom
Home"Wealth without money..."
Main.PonokoElectronicsLocationsr1.2 - 18 Feb 2009 - 04:52 - VikOllivertopic end
Start of topic | Skip to actions
Ponoko RepRap - Installing Opto Endstops
Full frontal of circuitry attached to Ponoko RepRap frame
Main Ponoko Page
Prev StepNext Step
BOM for this page
The stepper motor controllers and so forth can either be mounted on a board by the side of the RepRap, or fixed to the frame itself. Where you put them is a matter of personal choice and practicality: If you often move your RepRap around, it's handy to have the boards strapped to the framework. If you work on the circuitry a lot, it might well be handier to have them mounted on a board. Vik happens to be of the "mount it on the framework" persuasion, and the instructions below reflect this.
Using 8mm spacer to mount the Arduino shield square on Circuit boards may be secured using pairs of Clamps from the 5mm or 3mm acrylic sheets. Note that an 8mm M3 acrylic spacer is very handy for mounting boards at the crossover point of the bracing.
Obviously, make sure none of the circuit board components or metalwork touch the frame!
Use M3 spacers from the 3mm sheet to stop the solder spoiling the fit of the X Motor controller board on the back of the X Motor Bracket.
Mounting PWM and DC motor boards Mount the PWM board and the DC Motor board on the slots on the X Carriage. Feel free to put insulating material between the boards to avoid embarrassing shorts, but don't use anything that is likely to catch fire easily.
I mounted the thermistor board (or thermocouple board) with a cable tie through a 3mm hole drilled into the X Carriage. I'll update the cutting files to include this in the future.
Main Ponoko Page
Prev StepNext Step
BOM for this page
-- VikOlliver - 03 Jan 2009
to top
I Attachment sort Action Size Date Who Comment
dsc04618.jpg manage 79.3 K 03 Jan 2009 - 02:34 VikOlliver Full frontal of circuitry attached to Ponoko RepRap frame
dsc04620.jpg manage 73.6 K 03 Jan 2009 - 02:35 VikOlliver Using 8mm spacer to mount the Arduino shield square on
dsc04644.jpg manage 76.1 K 18 Feb 2009 - 04:51 VikOlliver Mounting PWM and DC motor boards
You are here: Main > PonokoRepRap > PonokoElectronicsLocations
to top
Copyright © 1999-2009 by the contributing authors. All material on this collaboration platform is the property of the contributing authors.
Ideas, requests, problems regarding RepRap? Send feedback
